Toner transfer paper
Discussion in 'General Electronics Chat' started by nerdegutta, Mar 30, 2014.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,565
    805
    Hi.
    I'm running out of transparent sheets for my UV LED exposure box. So before I'm all out, I thought I'd try the toner transfer again, being cheap on the transparents.
    My laser is a HP Laserjet P1102, and the paper I used is Canons Glossy Photo Paper "Everyday Use", GP-501, bought at Stapler in my town.
    This is the result:
    The circuit is a bi-polar step motor driver. The thinnest traces are 0.254 mm.
    I find this combination of printer and paper to work great!
    Just in case anybody else needs the info...:)
    thumb2, absf, Johann and 2 others like this.
  2. Little Ghostman
    Member
    Jan 1, 2014
    294
    97
    That is a great result! did you use a iron or a laminator? I use a laminator but for some reason photo paper dosnt seem to work well, so I use ultra thin magazine paper.
    But anyway well done thats a really good looking board!
  3. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thanks.
    I used an iron.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    If you have time to try other things, try the smooth paper from magazine sheets. I tried many many kinds of glossy papers and found magazine pages better than any of them. The magazine paper is so much easier to remove. run it under water and rub lightly; comes off so fast!
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    I've tried the thin magazine papers, but I couldn't get the results I wanted. I couldn't find a spot on the paper big enough to hold my circuit, so parts of an article or some ads got transferred to.
  6. strantor
    Oct 3, 2010
    4,302
    1,989
    Odd, I've never had that problem. Maybe the magazine you used was also printed by a laser printer. I use pages with full color photos, text, everything; I don't look for a "clean" spot. Never had an image or text imprint on my circuit.
  7. nerdegutta
    Dec 15, 2009
    2,565
    805
    Yes, that is odd. Guess I do something different.
    Oh, well, I got 90 photo-sheets to go, so I'm good for a while. :)
    strantor likes this.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have feeling I know the answer to this. but have tried the wax paper approach I spelled out in my article?
    How I make PCBs
    DerStrom8 and strantor like this.
  9. nerdegutta
    Dec 15, 2009
    2,565
    805
    Hi Bill.
    Yes, I've read your article several times. Usually I use UV, but running low on transparent sheet, I use the toner transfer for awhile. :)
  10. shortbus
    Sep 30, 2009
    4,088
    1,670
    The centerfold of Miss January, in Playboy has a pretty big blank spot in it, right below her neck. :p:D:eek:
    Johann, JohnInTX and Dr.killjoy like this.
  11. Little Ghostman
    Member
    Jan 1, 2014
    294
    97
    There is also a blank spot just above her neck :D
    GM11
    Johann, JohnInTX and shortbus like this.
  12. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    I use the writing since I can't read and only look at the pictures..
    JohnInTX likes this.
  13. cmartinez
    Jan 17, 2007
    3,698
    2,756
    too bad... you're missing out on great articles :p
  14. GopherT
    Nov 23, 2012
    6,303
    4,021
    About collecting wrist watches?
    DerStrom8 and cmartinez like this.
  15. nerdegutta
    Dec 15, 2009
    2,565
    805
    Back on track, sort of...
    What about making a laser machine that draw the graphic design?
    Any ideas?
    Yes, I have used Google, and I've seen a few DIY projects...
  16. cmartinez
    Jan 17, 2007
    3,698
    2,756
    You mean direct-to-board printing? Because that's been on my mind for a long time now.
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    Folks at Maker space have used the CO2 cutting laser to remove resist (paint). Can't say how well it worked.
  18. nerdegutta
    Dec 15, 2009
    2,565
    805
    Yes. That is on my mind.
  19. cmartinez
    Jan 17, 2007
    3,698
    2,756
    How about covering the board with a thin layer of toner powder, and then have an xy plotter solidify the traces with a dvd laser diode? The board would be shaken afterwards to get rid of the remaining toner powder. You think that might work?
  20. shortbus
    Sep 30, 2009
    4,088
    1,670
    cmartinez likes this.
