I need a post or link to a primer on tolerance information of going +/- 1 volt or more with same/different amperage and how dangerous that deviation is to 6V, 9V and 12V devices.
So I'd like to know the affects of using a power adapter that has
• Higher vs. lower voltage than the device asks for, +/- 1 volt vs. +/- 2 volts
• Higher vs. lower amperage specs than the device asks for
Background: An old Sega Genesis console says it needs a DC 9V 1.2A adaptor.
I had a bunch of 9V adaptors but they were 9V 200mA to 500mA range.
I also had a 10V 1.2A adaptor.
I resolved my original issue of SEGA Genesis console emitting a loud buzz, something it is apparently known to do, by trying several adaptors I had.
So once again the console says it needs a 9V 1.2A adaptor.
Buzzing went away with a 9V 500mA adaptor.
It was still there with a 10V 1.2A adaptor.
It was still there with a 9V 300mA adaptor.
What are the tolerances in general on this topic?
