Toggle on of with timer555 and relay 2 different voltages with relay HELP
Discussion in 'Homework Help' started by rastaman46, Nov 18, 2011.
Thread Status:
Not open for further replies.
  1. rastaman46
    Nov 17, 2011
    69
    Timer 555 and relay circuit with 2 different powers
    Hello im got circuit made of that image all works fine
    im using two power feeds
    one is 5V
    Other is 12V
    both can be run on same GND
    but i want insert spdt relay in it to be able to turn 12v ground to relay so i get 12v of relay to my motor
    ne555 is on 5v
    i try but bad luck
    once im switch power on its pover coil up all ok but im cant tur in off by pressing same momentary button i need disable graund manually to set relay to N-O position when relay on im got N-C
    can any one help please
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You've started this same thread in two places here in Homework and in Projects - which causes confusion. I've replied to your thread in Projects. Is this really homework?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
Thread Status:
