Today Quantum mechanics is "non-mechanical" theory.
Discussion in 'Physics' started by socratus, Jun 19, 2014.
  1. socratus
    Mar 26, 2012
    267
    Why?
    Because Classic Mechanics deals with objects that have real
    physical parameters : size, volume, geometrical forms and
    QM doesn't have real particles. In QM we are missed geometrical
    form of quantum particle.
    Real quantum particle cannot be a "point".
    Real quantum particle cannot be a "firm golf-ball" ( forbidden by SRT)
    Using models like "point-particle" or "firm golf-ball", we cannot describe
    QM in mechanical terms.
    One can adopt QM "visually" only understanding the mechanical model
    of quantum particle (!) . . . .. . and then giving forces to it . . .
    . . . . . see how this model works mechanically . . .
    . . . . and what is result of its mechanical behavior.
    Once again.
    QM is very practical theory and therefore it cannot be paradoxical.
    Its interpretation must be realistic. The best realistic way is
    to observe quantum particle as a simple mechanical object which
    somehow can produce quantum electrical (EM) effects.
    Einstein wrote:
    "Some physicists, among whom I am myself can not believe
    that we should once and for all abandon the idea of direct
    images of physical reality in space and time, or that we should
    agree with the opinion that a phenomenon in nature like a game case."
    /Einstein/
    How is it possible to see / to image geometrical form of quantum particle "direct"?
    In my opinion there is only one way to see / to image geometrical form
    of quantum particle "direct": we need to observe quantum particle in
    its own-native reference frame – zero vacuum T=0K.
  2. socratus
    Mar 26, 2012
    267
    " The mathematics of QM is straightforward, but making the
    connection between the mathematics and an intuitive picture
    of the physical world is very hard"
    / Claude N. Cohen-Tannoudji . Nobel Prize in Physics 1997 /
    The probabilistic solution of QM is only a top of an iceberg,
    the biggest part of this iceberg – the quantum deterministic
    process is hidden under the Dirac's "sea of vacuum".
  3. socratus
    Mar 26, 2012
    267
    The simplest way to understand something it is to see / to image
    it mechanically. Therefore, for example, Maxwell tried to
    understand and explain his EM theory using mechanical model.
    And Rutherford would begin thinking about a problem by forming
    for himself a simple picture without invoking too much mathematical
    detail. He used to say he didn't want to hear any physics that couldn't
    be explained to a barmaid. The same method used Fermi.
    " His methods were always simple, and he did not like complicated
    techniques. When a problem became complicated, he lost interest.
    But it must be explained that in Fermi's hands, problems that had been
    terrifyingly complicated for others often became very simple"
    / R. Peierls /
    If I want to follow Maxwell, Rutherford , Fermi then I need
    to take simple mechanical object and using it to explain physical
    problems.
    The mechanism of QM can be hidden only in its particles.
    QM begins with so called "virtual particles" that somehow can change
    into real physical particles. In order to understand mechanism of the
    "virtual action " I need to give to "virtual particles" some geometrical
    form and see / image how the mechanical behavior of "virtual particle"
    would produce QM effects.
    Every RF has influence on his "habitants".
    RF of sea create fish and RF of savanna create elephant.
    "Virtual particles" exist in Dirac's reference frame - "sea vacuum".
    This RF is negative 2D sea vacuum and therefore this RF can create only
    negative 2D virtual particles.
