Toaster modification
Discussion in 'The Projects Forum' started by Dan4954, Jan 21, 2013.
  1. Dan4954
    Jan 21, 2013
    6
    How would I be able to modify this circuit so that it stays on and I can control the temperature of the heating element?
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    You might be able to find a lamp dimmer rated to a wattage high enough to use with your toaster. It won't be cheap, since your toaster is probably over 1000 watts.
    In general, toasters are not temperature controlled. They're on or off.
    What are you really hoping to accomplish?
  3. Dan4954
    Jan 21, 2013
    6
    That's what I was thinking. I've been looking at electric hookah coals but the problem with them is that they don't get hot enough. Found this toaster laying around and i know this will get hot enough, just trying to figure out how to control it.
  4. mcgyvr
    Oct 15, 2009
    4,784
    973
    Just buy a vaporizer (volcano) and puff away stoner ;)
  5. Dan4954
    Jan 21, 2013
    6
    Haha just trying to eliminate the annoying coals for my hookah
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Lock switch in down position, look hard for a 1500W Dimmer (hard part)
  7. luvv
    Member
    May 26, 2011
    186
    31
    Wonder how much energy a burning coal is expending...I would venture a guess it's not 1KW..
    IF it was me,think I would skip the overpowered toaster and grab a soldering/wood burning iron of appropriate wattage and go from there.
  8. wayneh
    Sep 9, 2010
    12,368
    3,224
    Yeah, I though folks used "glow plugs" for this sort of thing.
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    My gasser model airplanes did not toke nor were Stoners. But they used a glow plug.
    Hookah?? Many of the Arab people in the park smoke a hookah water pipe. They light it with a lighter, not with an electric toaster.:rolleyes:
