TO220 Packages Pspice Models
Discussion in 'Electronics Resources' started by kampfer, Dec 8, 2014.
  1. kampfer
    Nov 11, 2014
    32
  2. kampfer
    Nov 11, 2014
    32
    nevermind i found models. thanks anyway.
  3. kampfer
    Nov 11, 2014
    32
    what kind of feedback can i use instead of op-amp with regular resistance?
  4. kubeek
    Sep 20, 2005
    4,687
    805
    What does that sentece even mean? You probably could use some discrete differential amplifier made of only transistors and resistors, but that would be much more complicated than simply using some opamp.
  5. kampfer
    Nov 11, 2014
    32
    i want to a feedback system for circuit on the link. unfortunately i cannot use op-amp. just r, l, c, bjt and fet components.
  6. kubeek
    Sep 20, 2005
    4,687
    805
  7. atferrari
    Jan 6, 2004
    2,663
    784
    TO220.
    Is it relevant for a Spice model?
  8. kampfer
    Nov 11, 2014
    32
    it is power amplifier package. i've decided to use tip41.
    it is pretty complex but i'll be good. thanks.
