TO220 Heatsink
Discussion in 'General Electronics Chat' started by selfbg, Feb 4, 2012.
  1. selfbg
    Jun 11, 2010
    23
    I cant find anywhere heat sink for TO220 with the spec:
    The total power is ~70W.
    So "theta" sink-to-ambient = 0,92°C/W.
    It doesn't matter natural or forced cooling.
    Thanks in advance. :)
  2. #12
    Nov 30, 2010
    16,657
    7,300
    aavidthermalloy.com has heat sink calculators and air velocity calculators. That might lead you to a product that you can buy.
  3. selfbg
    Jun 11, 2010
    23
    I checked the site, but still can't find suitable heat sink.
  4. #12
    Nov 30, 2010
    16,657
    7,300
    Part # 530002B02500G is the largest TO-220 sink listed at Aavid. It's free air theta is 2.6
    The only cure for that is air velocity. Clicking on that part number brings you to a page which has a graph of velocity vs. theta. www.avidthermallow.com/products/standard/53002b02500g
    The answer is 1000 feet per minute.
  5. crutschow
    Mar 14, 2008
    13,469
    3,356
    For that much power a heatsink with an integrated fan would likely be best. Perhaps you can adapt a CPU cooler for PC to your needs such as one of these.
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  7. #12
    Nov 30, 2010
    16,657
    7,300
    There is also the option of using a different (bigger) package. A TO-3 plus proper heat sink and fan might be smaller than a TO-220 with proper heat sink and fan.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I like the CPU heatsink/fan idea myself. You will have to drill/tap the holes yourself.
  9. jimkeith
    Oct 26, 2011
    539
    99
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    To get 0.9C/W you need an extruded heatsink, very large and heavy. probably about 12" wide, 4" high.
    BTW: if power dissipation forces the use of a heatsink < 1C/W, TO-220 devices are a poor choice. They have a theta of about 4C/W from junction to case. TO-3 is a much better choice.
  11. bountyhunter
    Sep 7, 2009
    2,498
    507
    CORRECT. Thermal resistances add in series. The 4C/W junction-case of the TO-220 is MUCH larger than 0.9C/W. Going to the TO-3 which is <1C/W junction-case saves most of the total thermal resistance.
