to vary the speed of dc motor without varying its speed
Discussion in 'General Electronics Chat' started by narinder kaur, Feb 19, 2016.
  1. narinder kaur
    Feb 19, 2016
    Hi,i am an engineering student i want to vary the speed of a dc motor without varying its power. Plzz help me!!
  2. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    First off you may wish to correct this thread's title;)
    The required input power will be a function of AV (i.e. 'speed'), load and efficiency --- I'm uncertain as to your meaning with 'not vary the power'...:confused:
    IOW -- More info please!:)
    Best regards
    HP:)
  3. crutschow
    Mar 14, 2008
    13,523
    3,390
    Plzz explain your problem better (whatever plzz means :confused:).
    What type of dc motor?
    You can vary the speed of a shunt-field dc motor by varying the field current.
  4. hp1729
    Nov 23, 2015
    2,105
    235
    Vary the burden as well.
    panic mode likes this.
  5. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    FWIW I'm guessing the OP's intent is that he/she wishes to vary the AV sans 'static' adjustment of the feed EMF --- Still, who knows...:confused::rolleyes:
    Best regards
    HP
  6. Dodgydave
    Jun 22, 2012
    5,167
    777
    Sounds like they want to alter the speed without altering the voltage or current through the motor, o_O
    Its a job for Super-hamster!!! :D
    Hypatia's Protege likes this.
  7. Jonathan Durrant
    Jul 5, 2015
    Pulse width modulation allows you to control the 'speed' of a motor without changing the voltage by changing the duty cycle - but in an AC setting. If you use an ac power source and a filter circuit (Google is your friend) to prevent it from dipping below 0V, you might have some luck.
  8. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    @narinder kaur -- Pursuant to the above - Please consider, for instance, a 'phase control' circuit but employing an SCR (as opposed to a triac) as the power switching device... Be advised, however, that a (monopolar) PWM controller is the standard (and, in most applications, optimal) approach...
    Best regards
    HP
  9. SLK001
    Nov 29, 2011
    852
    243
    The OP probably means "how do I vary the speed of a DC motor without varying its torque". One word: Pulse Width Modulation.
