To understand Transimpedance in CCVS
Discussion in 'The Projects Forum' started by cadamhill, Oct 22, 2015.
  1. cadamhill
    Oct 10, 2015
    27
    I am designing a circuit to read current and convert the signal from A to D . I need to get the final signal out to the ADC in the form of 5V AC using the standard format of 5-20mA. I will worry about level shifting and precision rectifiers later (which will help me get the signal to 1 - 5V AC based on input current. We are using an LA55-P Current transducer for the CCVS and have no idea the transimpedance to consider for the project. The LA55-P has a 1:1000 step down ratio. Tha manufacturer recommends we use a 100ohm measurement resistor. Because I cannot find the part in multisim so I have to create the part. It is asking me for the transresistance (H) for the CCVS. What do I do here? Thanks.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    In LTSpice, the archaic CCVS has been replaced by a Behavioral Voltage source, where it's output voltage is any arbitrary function of node voltages, branch currents, or Time...
    Here I set the trans-impedance to 3V/A, where the voltage is 3* the current in R1.
    Otherwise, this is what the LTSpice help file says about a CCVS:
    cadamhill likes this.
  3. cadamhill
    Oct 10, 2015
    27
    I'm sorry Mike. What? Please try to explain this like I don't know how to solve the problem. Please don't assume I know anything.
  4. cadamhill
    Oct 10, 2015
    27
    Got it now. thank you.
