TO: THE “ALL ABOUT CIRCUITS” WEB SITE MEMBERS
REFER TO THE ATTACHED SCHEMATIC while reading the explanation (a .jpg file)
I have a problem with ½ of a 2 section power supply board that supplies +47 volts to a pulpit microphone via several pre-amplifiers. The board is part of a Electro-Voice B-42 Stereo Mixer Panel.
The voltage at the input to the bridge rectifier reads 63V AC (and looks normal). At the rectifier output, the voltage reads 83V DC.
______________________________________________________________________
The voltage at the output of the circuit should read +47 volts, but reads 0v (no load)
The problem appears to be at the “pass transistor” (TIP28C) Q554. The indications are that it is not conducting. I have replaced it and the transistors (Q551 & Q552) that drive the TIP28C with NTE replacement transistors bought at FRY’s electronics.
The voltage measurements at (TIP28C) Q554, with Q551 removedand Q552 installed, are as follows:
Emitter to ground = 12.7V
Base to ground = 13.7V
Emitter to ground = 82V
The voltage measurements at (TIP28C) Q554, with both Q551 and Q552removed, are as follows:
Emitter to ground = 55.1V
Base to ground = 54.7V
Emitter to ground = 78.6V
Zener diode 1N5261 was also replaced. The original was a 1/4w component, but only a 1/2w unit was available. The voltage across the 390Ω resistor is 1.83v which is connected
in series with the Zener diode.
Any help would be appreciated to get this circuit functioning again.
SM1WRI
SM1WRI
