Hi, i am a newbie in programming.
I am working to start a timer0 and show it's timing on LCD. I would like to make the timing like a stopwatch.
Please help me I have tried to write out and troubleshoot the coding for the past few days. Yet i got no result from it.
The LCD is working out fine (i have tried working only on the LCD).
Please advise me on my errors. Thank you so much.
These are my coding:
#include <p18f4620.h>
#include <stdio.h>
#include <delays.h>
#include <init_testing.h>
#include <timers.h>
#include <init_timers.h>
#pragma config LVP = OFF, PWRT = ON, WDT = OFF
#pragma config PBADEN = OFF
#pragma config DEBUG = OFF
void delay_ms(unsigned int);
void delay_20us(unsigned int);
void functionSet(void);
void entryMode(void);
void displayOn(void);
void displayClear(void);
void sendChar(char c);
void enable (void);
void sendString(far rom char *str);
void moveTo2nd(void);
unsigned long int tick_count, hour2, minute2, second2, milisecond2;
unsigned long int rec_hour, rec_minute, rec_second, rec_milisecond;
unsigned char hour, minute, second, milisecond;
char outchar; // character to send to the LCD
char int_2_char (unsigned char int1);
void main(void)
tick_count, hour2, minute2, second2, milisecond2 = 0;
rec_hour, rec_minute, rec_second, rec_milisecond = 0;
milisecond = 99;
second = 60;
minute = 60;
hour = 10;
// init timer0
RCONbits.IPEN = 1; // Enable Priority Features
INTCON2bits.TMR0IP = 1; // TMR0 Overflow Interrupt Priority bit = HIGH
INTCONbits.TMR0IF = 0; // Clear timer0 interrupt flag
INTCONbits.GIE = 1; // Enable global interrupt
INTCONbits.PEIE = 0; // disables all low priority peripheral interrupts
INTCONbits.TMR0IE = 1; // Enables the TMR0 overflow interrupt
// init LCD
TRISD = 0; // define Port D as output
displayClear();
Delay10TCYx(200); // delay for 200us
functionSet();
entryMode();
displayOn();
while(1);
#pragma code
#pragma interrupt T0ISR // Timer0 -- interrupt service routine
void T0ISR(void)
INTCONbits.GIE = 0; // disable global interrupt
INTCONbits.TMR0IE = 0; // Disables the TMR0 overflow interrupt
for(tick_count = 0; tick_count<milisecond; tick_count++) //count til 98
milisecond2++;
rec_milisecond = milisecond2; // recorded
if (rec_milisecond >= 99) // 1second is up
tick_count = 0; // reset
milisecond2 = 0;
for(tick_count = 0; tick_count<second; tick_count++) //count til 59
second2++;
rec_second = second2; // recorded
if (rec_second >= 59) // 1minute is up
second2 = 0;
for(tick_count = 0; tick_count<minute; tick_count++) // count til 59
minute2++;
rec_minute = minute2; //recorded
if (rec_minute >= 59) // 1hour is up
minute2 = 0;
for(tick_count = 0; tick_count<hour; tick_count++) // count til 9
hour2++;
rec_hour = hour2; // recorded
if (rec_hour >= 9)
hour2 = 0;
// send "time = mm:ss" to LCD display
sendString(" Lap 1");
moveTo2nd();
sendChar('T');
sendChar('i');
sendChar('m');
sendChar('e');
sendChar(' ');
sendChar('=');
sendChar(' ');
outchar = int_2_char (rec_minute);
sendChar(outchar);
sendChar(':');
outchar = int_2_char (rec_second);
sendChar(outchar);
sendChar('.');
outchar = int_2_char (rec_milisecond);
sendChar(outchar);
return;
// function to convert unsigned char to char (for display)
char char1;
switch (int1)
case 0 : char1 = '0' ; break;
case 1 : char1 = '1' ; break;
case 2 : char1 = '2' ; break;
case 3 : char1 = '3' ; break;
case 4 : char1 = '4' ; break;
case 5 : char1 = '5' ; break;
case 6 : char1 = '6' ; break;
case 7 : char1 = '7' ; break;
case 8 : char1 = '8' ; break;
case 9 : char1 = '9' ; break;
default : char1 = '?' ;
return(char1);
void functionSet(void) // 0010 1010 - 4 bit mode, 2 lines, 5 X 8.
RS= 0;
DB7 = 0; // Upper nibbles
DB6 = 0;
DB5 = 1;
DB4 = 0;
enable();
Delay10TCYx(200);
enable();
DB7 = 1; // Lower nibbles
enable();
Delay10TCYx(200);
void enable(void)
E = 1;
Delay10TCYx(1);
E = 0;
void entryMode(void) //0000 0110, increment with no shift
RS = 0;
DB6 = 0;
DB5 = 0;
DB4 = 0;
enable();
DB6 = 1; // Lower nibbles
DB5 = 1;
enable();
Delay10TCYx(80);
void displayOn(void) // display on, cursor off, blink off
RS = 0;
DB6 = 0;
DB5 = 0;
DB4 = 0;
enable();
DB6 = 1;
DB5 = 0;
DB4 = 0;
enable();
Delay10TCYx(80);
void displayClear(void) // display clear
RS = 0;
DB6 = 0;
DB5 = 0;
DB4 = 0;
enable();
DB7 = 0; // Lower nibbles
DB6 = 0;
DB5 = 0;
DB4 = 1;
enable();
Delay10TCYx(80);
int index = 0;
while (str[index] != '\0')
sendChar(str[index]);
index++;
void sendChar(char c) // send character to LCD
RS = 1;
DB7 = (c >> 7) & 1;
DB6 = (c >> 6) & 1;
DB5 = (c >> 5) & 1;
DB4 = (c >> 4) & 1;
enable();
DB7 = (c >> 3) & 1;
DB6 = (c >> 2) & 1;
DB5 = (c >> 1) & 1;
DB4 = (c & 1);
enable();
Delay10TCYx(80);
void moveTo2nd(void) //1100 0000 - move cursor to 2nd line
RS = 0;
DB7 = 1; // Upper nibbles
DB6 = 1;
DB5 = 0;
DB4 = 0;
enable();
DB7 = 0; // Lowr nibbles
DB6 = 0;
enable();
Delay10TCYx(80);
#include <stdio.h>
#include <delays.h>
#include <timers.h>
void enable (void);
void main(void)
milisecond = 99;
second = 60;
minute = 60;
hour = 10;
// init timer0
// init LCD
displayClear();
functionSet();
entryMode();
displayOn();
while(1);
#pragma code
void T0ISR(void)
milisecond2++;
milisecond2 = 0;
second2++;
second2 = 0;
minute2++;
minute2 = 0;
hour2++;
if (rec_hour >= 9)
hour2 = 0;
moveTo2nd();
sendChar('T');
sendChar('i');
sendChar('m');
sendChar('e');
sendChar(' ');
sendChar('=');
sendChar(' ');
sendChar(outchar);
sendChar(':');
sendChar(outchar);
sendChar('.');
sendChar(outchar);
return;
char char1;
switch (int1)
return(char1);
RS= 0;
DB6 = 0;
DB5 = 1;
DB4 = 0;
enable();
Delay10TCYx(200);
enable();
enable();
Delay10TCYx(200);
void enable(void)
E = 1;
Delay10TCYx(1);
E = 0;
RS = 0;
DB6 = 0;
DB5 = 0;
DB4 = 0;
enable();
DB5 = 1;
enable();
Delay10TCYx(80);
RS = 0;
DB6 = 0;
DB5 = 0;
DB4 = 0;
enable();
DB6 = 1;
DB5 = 0;
DB4 = 0;
enable();
Delay10TCYx(80);
RS = 0;
DB6 = 0;
DB5 = 0;
DB4 = 0;
enable();
DB6 = 0;
DB5 = 0;
DB4 = 1;
enable();
Delay10TCYx(80);
int index = 0;
index++;
RS = 1;
DB7 = (c >> 7) & 1;
DB6 = (c >> 6) & 1;
DB5 = (c >> 5) & 1;
DB4 = (c >> 4) & 1;
enable();
DB7 = (c >> 3) & 1;
DB6 = (c >> 2) & 1;
DB5 = (c >> 1) & 1;
DB4 = (c & 1);
enable();
Delay10TCYx(80);
RS = 0;
DB6 = 1;
DB5 = 0;
DB4 = 0;
enable();
DB6 = 0;
enable();
Delay10TCYx(80);
