To measure possible fluctuations in 50Hz AC to a load
Discussion in 'The Projects Forum' started by philiper, Mar 14, 2009.
  1. philiper
    Mar 14, 2009
    Looking into using a 'hall effect' current sensor to measure current in a high voltage line(AC-50Hz -4000V-600mA). The line supplies a magnetron (MW generator) via a 'coupling connected' high voltage cap. My goal is not to 'know' the current but to notice possible voltage fluctuations (signs of iminant failure) accross the cap and display on PC. Was thinking of connecting sensor up to current to voltage amplifier then input to ADC card for laptop.
    Any thoughts? is it possible to get a ratio type current sensor? i.e. divide by 10 current sensor.
    would it be possible to detect volatage fluctions (errors...and not the expected sine) on the positive side of the cap?
    thanks
  2. quentin7406
    Mar 19, 2009
    Just a thought but have you considered using a clamp on ammeter connected to computer port to record the values.
