to help little circut
Discussion in 'General Electronics Chat' started by M.Naeem, Dec 24, 2007.
  1. M.Naeem
    Dec 24, 2007
    dear .i want use 3 bulb each is 12v 4A.But i am using battery 12v 4.5 AH dry battery.some relay or circut to help my circut not much load apply on battery thx. Naeem
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Deepest apologies dear, but I do not understand your requirements.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I suggest either using smaller bulbs or bigger batteries.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Definitely bigger battery, with the bulbs in parallel.
  6. David Bridgen
    Feb 10, 2005
    278
    If I understand correctly, you want to use the 12V 4.5Ah battery to power three 12V 4A bulbs.
    You also want a "relay or circuit" which will reduce the load of those bulbs on the battery.
    If you want the bulbs lit continuously at their full power there's nothing you can do to reduce the power drain from the battery.
    The only way to reduce power from the battery is to reduce the power taken by the bulbs, either by switching them on and off rapidly, or less satisfactorily by putting resistance in series with each bulb (which is wasteful).
  7. BlueDevry
    Member
    Dec 26, 2007
    22
    Could a SCR be used to do the switching ?
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, you could use an SCR to turn the lamps ON, but you wouldn't be able to turn it OFF unless you:
    1) Disconnected the battery
    2) Used an inductive kick to momentarily bring the voltage across the SCR to zero, allowing it to turn off.
    3) Wait for the battery to be dead. (Don't worry, in this scenario you won't have long to wait. :rolleyes:)
  9. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    One option for using an SCR would be to run a motor with the battery and run an alternator with the motor. Then the SCR could be used to control the AC. Rube Goldberg would be proud.
    PWM would be simpler, less expensive, and more compact.
