To get -30 from +30V supply
Discussion in 'General Electronics Chat' started by sharmilla, Dec 8, 2008.
  1. sharmilla
    Nov 3, 2008
    17
    Hi all,
    anyone could suggest me, on how to get - 30V from a +30V supply.
    Many Thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you only need a single supply, simply reverse the leads. That could make a ground reference interesting, depending on the power supply.
  3. sharmilla
    Nov 3, 2008
    17
    Is it attached....
  4. Dominick
    Member
    Dec 6, 2008
    28
    What are you powering?
    Anything Iv ever seen that had a -volt had a ref ground
    +30 -30 about 60 volts + to - correct?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Reversing the leads will reverse the voltage polarity relative to ground..
  6. leftyretro
    Nov 25, 2008
    394
    Yes this can sometimes be a concept difficult for a beginner to get their head around. An isolated (transformer coupled) fixed DC power supply just supplies current at a specific potential (voltage) difference. The concept that it is a + or - DC supply all depends on which terminal is going to the circuit common of the application circuit.
    So for say a general purpose analog op-amp type circuit requiring both positive and negative voltages and a circuit common, one can use two identical isolated (transformer coupled) power supplies. One supply would have it's positive terminal wired to the breadboards common (ground) connection and the other supply would have it's negative terminal wired to breadboard common. The opposite terminal on each power supply would become the circuit negative and positive voltages respectively.
    This does not apply to non-isolated DC power supplies where one terminal is hardwired to a power common, (or neutral) connection and you are not free to swap polarities simply reversing connections to your application.
  7. sharmilla
    Nov 3, 2008
    17
    Please find as attached.. I have attached two circuits in it.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    It looks like you are drawing a P-channel Mosfet. That has an intrinsic diode from drain (anode) to source (cathode). The top circuit should not have worked, becasue the diode would be forward biased and always on.
    The bottom circuit is the correct orientation, but you may have problems turning off the gate with that configuration.
    John
  9. sharmilla
    Nov 3, 2008
    17
    Im sorry error in the diagram...both the mosfets are Nchannel mosfets...IRFP460....ok so for the bottom circuit i have to run it using a P-channel mosfet if i provide a - voltage ...
    and for the top circuit i have to use N-channel mosfet if i provide a + voltage
    am i rite ...
    many thanks
  10. jpanhalt
    Jan 18, 2008
    5,699
    909
    If the bottom circuit's mosfet is N-channel, then its diode is forward biased. To avoid getting a lot of confusion going here, I think you need to redraw the schematic you intend to use, including the gate drive, then proceed with trying to make it work.
    John
  11. sharmilla
    Nov 3, 2008
    17
    dear all,
    I redrew the circuit as attached... is this correct ...
  12. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The gate signal MUST be of the correct polarity and magnitude with respect to the source. Please show your gate drive circuit.
  13. sharmilla
    Nov 3, 2008
    17
    Hi the gate drive signal is similar to as attached ..please advise
