to find the current during the transient
Discussion in 'Homework Help' started by martincho8002, Jan 12, 2008.
  1. martincho8002
    May 26, 2007
    12
    I need urgent help on this one.I should first simplify the circuit I guess and may be write an equivalent ressistance.First we have the switch off , and then on.Thanks in advance.
  2. scubasteve_911
    Dec 27, 2007
    1,202
    I would solve this circuit via laplace transformation. You need solve a couple systems of equations obtained via nodal and/or current mesh analysis.
    So, rewrite the circuit via laplace transform. Changing inductance to Ls, adding source, etc. Then, write equations with those components. Solve, then do inverse transform.
    I have done too many of these in the past, so I will let you take a crack at it.
    Steve
  3. martincho8002
    May 26, 2007
    12
    Solved it on another method. Thanks for the help , your method is easier , but I had someone to explain the other one to me in details
