To decouple or not
Discussion in 'General Electronics Chat' started by morganism, Apr 15, 2012.
  1. morganism
    Apr 13, 2012
    After lusting after the Gecko EFM prototyping board, saw some articles in the DigiKey catalog talking about "sprinkling" caps all over your designs.
    It was pointing out how big a power draw it was to do that, basically cutting battery life in half.
    Where is the tradeoff point for de-bouncing, and quick to sleep and rise ?
  2. chrisw1990
    Oct 22, 2011
    543
    41
    i have always taken the general practice to decouple often..
    its not so much noise, but about the power draw from items like uC's etc..
    the general rule i apply is such:
    near the psu, apply a larger cap, lets say 10uF, and next to an IC.. of small proportion, place 10n or 100nF.. for uCs id lean more towards 100nup to 1u. though they usually require multiple caps anyway so they all add up.
    power draw isnt really an issue..
    the minute value to which inrush current is increased.. meh, and i personally wouldnt run anything directly from a battery.. maybe a torch, but i buy them, dont design them..;)
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Please provide a link to that article. I can't believe Digikey would make that statement.
  4. #12
    Nov 30, 2010
    16,705
    7,358
    I second that. Decoupling caps don't eat up batteries. There must be a mistake happening here.
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    Large de-bouncing capacitors on lines that were switched frequently enough could conceivably add significant power consumption to a system.
    Generally however, supply decoupling capacitors only require an inrush of current at power-up,and unless powering up and down is extremely frequent this is normally acceptable. These capacitors are generally not optional, as it is otherwise difficult to obtain the low power supply impedances required to keep rail voltages steady in face of rapid current variations.
