to control charging of battery by using PWM
Discussion in 'The Projects Forum' started by no name, Apr 7, 2015.
  1. no name
    Apr 7, 2015
    I want to make a circuit that will control the charging of battery by using PWM. Can any one help me?
  2. R!f@@
    Apr 2, 2009
    8,792
    771
    Welcome to AAC.
    Is this a project?
    If so show us what you have done already.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Why do you need to use pwm?
  4. crutschow
    Mar 14, 2008
    13,508
    3,384
    PWM is only needed if you really require a higher charging efficiency than a linear regulator can provide.
    And you will need a feedback loop to control the current which is generally most easily done with an IC switching regulator chip.
  5. ScottWang
    Aug 23, 2012
    4,933
    777
    I heard a friend said that there is someone in Taiwan that he applied a patent about the charging method, it seems used 90% to do the charging work and used 10% to do the discharge work, he claimed that is the best way for the batteries.
  6. ScottWang
    Aug 23, 2012
    4,933
    777
