to construct inductor
Discussion in 'General Electronics Chat' started by rabiya, Nov 20, 2011.
Thread Status:
Not open for further replies.
  1. rabiya
    Nov 20, 2011
    can anyone please tell me the accurate parameters for constructing 1nH and2.2nH.............please...i need it urgently.......
    thanks in advance
  2. steveb
    Jul 3, 2008
    2,433
    469
    Those are very small values, in the range of stray inductance of leads and wires; hence, it's very difficult to get accurate parameters. But, a straight piece of wire less than 1 cm in length, or a small single turn loop inductor, of even smaller diameter, might get you in that range. If you are making a printed circuit board, then you can make a trace behave as the inductor.
    You need to know current levels to get the right wire diameter.
    rabiya likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You couldn't use a whole loop. More like a slight kink in a very short piece of wire.
    The leads on a TO220 package have somewhere between 4nH and 8nH inductance, depending on how long you cut them off - and they are straight and flat.
    rabiya likes this.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    1/2 turn of a 1/4 watt resistor wire around a 1/4 watt resistor is about 5nH, can't really tell since my hand near it changed the reading a lot.
    Are you sure you didn't mean millihenry or microhenry?
    rabiya likes this.
  5. rabiya
    Nov 20, 2011
    no no its nH only.
    thanks a lot to you people.
  6. steveb
    Jul 3, 2008
    2,433
    469
    I think that's true from a practical point of view. The reason why I mentioned this is because a single loop inductance formula indicated that a 36 gauge magnet wire wound with a 1 mm single loop would make a 1.4 nH inductor. This is barely in the practical range, but then one needs to consider lead connections and the difficulty of doing this accurately.
    It would be interesting to know the details of the application and the frequency range. Is this a radio frequency design, ... microwave ... ? What are the other components in the system, what is their size and how are they connected?
  7. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    The circuit you show is a cell phone jammer.
    Those circuits are NOT allowed over here.
    Bertus
Thread Status:
