To choose a capicitor for active filter
Discussion in 'General Electronics Chat' started by Crowbar, Dec 28, 2006.
  1. Crowbar
    Thread Starter Active Member
    Dec 19, 2006
    32
    I need 10mkf capicitor for a HPF(it will be a part of portable magnetometer). Better to use polypropylene but 10mkF polyprop. cap. is bulky- what about tantalum or ceramic?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Tantalum is polar and has wierd characteristics when exposed to AC. They tend to short, for instance. Ceramic is hard to use. The specs are usually the value +80% to - 20%. Not too accurate, which is critical for filtering. And they tend to be microphonic, and contribute noise when shaken or vibrated.
    You have to choose components based on application and not necessarily on size.
  3. Distort10n
    Dec 25, 2006
    429
    I would go with the ceramic or silver-mica. I would not worry about noise contributed by microphonics unless your application is going to be subjected to shocks/vibrations as part of the application itself. Ceramics are typically used in high speed applications; e.g., DSP's.
  4. Crowbar
    Dec 19, 2006
    32
    The system is working with frequencies from dc to 1KHz and with a voltage ranges 30mkV-2V
  5. atferrari
    Jan 6, 2004
    2,663
    783
    10mkf and 30mkV (?!)
    Weird units, at least to me...
    What do they mean? NEVER seen them.
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Interpreting this literally:
    10mkf = 10f
    30mkV = 30V
    Some clarity is needed.
    Dave
  7. kubeek
    Sep 20, 2005
    4,687
    805
    mkF means usually microfarads (mikrofarads) or uF.
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    As a terminology this is very confusing, I could understand mcF, but mkF implies milli-kilo-Farad which (interpreted literally) means Farad. Thankfully I haven't come across this terminology before.
    Thanks for the clarification anyway.
    Dave
  9. Crowbar
    Dec 19, 2006
    32
    I'm Russian that's why I have posted mkF istead of uF :)
  10. wireaddict
    Nov 1, 2006
    133
    If you're using a 10uF cap, electrolytics are the only ones that large [at least, that I know of, that are commonly available]. Also, the cap needs to be a non-polarized type since it will have AC applied to it.
  11. Distort10n
    Dec 25, 2006
    429
    That is not necessarily true. As long as both sides of the cap are DC biased then AC squiggles are ok. You see this in video apps with TV's from time to time.
  12. wireaddict
    Nov 1, 2006
    133
    Yes, a DC/polarized electrolytic will work fine provided the AC voltage never exceeds the DC in the wrong direction; however Crowbar never said that there would be DC with superimposed AC on this cap. Not knowing the voltage on this cap I suggested using a N/P type. Regards.
  13. lenin
    Jan 2, 2007
  14. wireaddict
    Nov 1, 2006
    133
    But does the capacitance of ceramic or silver mica caps go that high [10uF] [and at a reasonable price]? If so, I agree, either would be a better choice than electrolytics here.
  15. Murod
    Dec 24, 2005
    30
    When applied to AC voltage with unknown bias, two back-to-back series electrolytic capacitors can be a cheap solution.
    Hasan Murod.
