I get datasheets from www.datasheetarchive.com where I can select from a list of manufacturers. Usually I select the manufacturer who designed the original part because some copy-cat manufacturers make errors or do not provide details on their datasheet.
Best to use the data sheet from the manufacturer of the part you have though. Some parts by different makers use a different pin-out. Pins may not be the same connection internally from one company to another on discrete components.
