Hey all,
i'm trying to set up timer 1 on a pic18f4550 in compare mode with the CCPregisters.
When i simulate i see TMR1L go to 0xFF and then to 0x00 but the upper byte of TMR1 does not increment? I do not know what i'm doing wrong.
I use the pic18f4550, mplab ide environment, c18 compiler en a ICD3 debugger
Here is my setupcode:
does anyone see what i'm doing wrong?
Rich (BB code):
void setupTimer()
const tLong constValueForCCPR1 = ((configTICK_TIME * (OSC_FREQ / OSC_PER_INST)) / 1000 ); //1000 is om msec van tick_time aan te passen
tLong valueForCCPR1;
//timecount clearen
TMR1H = (tByte) 0x00;
TMR1L = (tByte) 0x00;
//waarde in CCPR1 register steken
valueForCCPR1 = constValueForCCPR1;
CCPR1L = ( tByte ) ( valueForCCPR1 & ( tLong ) 0xff );
valueForCCPR1 >>= (tLong) 8;
CCPR1H = ( tByte ) ( valueForCCPR1 & ( tLong ) 0xff );
//Compare mode
CCP1CONbits.CCP1M0 = SET_BIT;
CCP1CONbits.CCP1M1 = SET_BIT;
CCP1CONbits.CCP1M2 = CLEAR_BIT;
CCP1CONbits.CCP1M3 = SET_BIT;
//alle instellingen qua timer1 en interrupts voor timer1
PIE1bits.CCP1IE = SET_BIT; // CCP1 Interrupt Enable
//IPR1bits.TMR1IP = SET_BIT; // CCP1 Interrupt Priority High
T1CONbits.TMR1CS = CLEAR_BIT; // Timer 1 Clock Source Bit -- zero equals internal clock
T1CONbits.T1CKPS1 = CLEAR_BIT; // Prescale value
T1CONbits.T1CKPS0 = CLEAR_BIT; // Prescale value
T1CONbits.RD16 = SET_BIT; // Enable 16bit mode
T3CONbits.T3CCP2 = CLEAR_BIT; //Timer3 and Timer1 to CCPx Enable bits
T3CONbits.T3CCP1 = SET_BIT; //Timer3 and Timer1 to CCPx Enable bits
T1CONbits.TMR1ON = SET_BIT; // Timer 1 On Bit
//freeRTOS gebruikt INTCONbits.GIEL nog, ma ik denk dak die ni moet gebruiken?
//INTCONbits.INT0IE = CLEAR_BIT; //deze regel moet eerder bij startscheduler
INTCONbits.GIEL = SET_BIT;
//RCONbits.IPEN = 0;
INTCONbits.GIEH = SET_BIT;
