TMP 36 and meter
Discussion in 'General Electronics Chat' started by aac9876, Nov 26, 2009.
  1. aac9876
    Thread Starter Active Member
    Dec 9, 2006
    124
    to use this temp sensor you need a voltage source.
    Anyone make a small homemade voltage source and sensor rig all in
    one that is cheap and worth copying.
    And would it be ok to glue or silicon this sensor onto an aluminum surface..?? it will be used for the 100F to 300 F range.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    TMP36's have a limit of 125°C, which is 257°F.
    You'd need a temp sensor that goes up to 150°C (302°F) or higher.
    You'll probably need to use a thermistor or perhaps a thermocouple.
  3. aac9876
    Dec 9, 2006
    124
    257 is good enough
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See page 11 of the datasheet, upper left corner.
    A TMP36, two resistors, a 0.1uF capacitor. You could power it with two or three AA or AAA batteries in series, and use a voltmeter in the mA range to read the output. Just subtract 58 from the mA reading, and you'll have the temp in °F.
