1. I have to connect a 3W white led light as here: http://tinyurl.com/jpj3gnu & control its intensity using a 10K potentiometer.
2. If = 0.7A
Vf min = 3.2V
Vf max = 4.0V
Input voltage range: 5.4V to 8.4V
I think TLE4309 should work in this application.
3. Max adjustable current in IC: 500mA
So to be on same side I keep max 450mA.
Vref = 178mV.(From table)
so Rref = 178mV/450mA = 0.3955ohm
This is very close to 0.39ohm minium of Rref. Should I select higher resistance value then this r this is also ok? But if I go higher then Iref will reduce further & led will glow less.
4. Pin connection
Pin1: Connected to input voltage 5.4V to 8.4V, decoupled by 0.1uF
Pin3: Open
Pin4: Ground
Pin5: 0.39ohm shunt
Pin6: Open
Pin7: Led connected
Query:
1. Now I want to control the intensity of the led through 10K potentiometer. How do I do it?
Should I connect one terminal of potentiometer to pin1 i.e input, third terminal to pin4 i.e ground
and middle pin of pot to Pin2 of TLE4309.
Will this work?
2. If = 0.7A
Vf min = 3.2V
Vf max = 4.0V
4. Pin connection
Pin3: Open
Pin4: Ground
Pin5: 0.39ohm shunt
Pin6: Open
Pin7: Led connected
Query:
Will this work?
