I need a voltage sensing window comparator opamp subsitute for TLC272. Would you please advise an alternative. An LM386 will provide input from an electret mic. The application is a noise monitor for our elementary school cafeteria. Thank you.
I am inexperienced and am looking at a Forrest Mims circuit that uses the TLC272 that activates three led's, depending upon voltage input. I have been working at this project daily for two months without success. The voltage senser circuit is a new tack. I am hoping the output can be used as digital input to an Arduino for further data processing. Analog readings from an LM386 ("Physical Computing") are unstable, even after hysterisis, because the range is too narrow. Hopefully, the window comparator will be easier to calibrate. Any advise is very much appreciated.
I should have been able to use the output of this circuit to enable LED's from the Arduino but failed time and again as the led's would jump about whenever values are close.
The LM386 circuit is missing some of the important parts recommended on the datasheet of the LM386.
There is supposed to be a 10 ohms resistor in series with a 0.05uF (0.047uf) capacitor at the output to ground to prevent oscillation.
There is supposed to be a supply bypass capacitor at the IC.
The author does not know what he is talking about. The output voltage of the LM386 is already +2.5V and the two 100k resistors do nothing. The +2.5V is changed by the signal to +1V to +4V.
