I wanted to use a single supply opamp to sense near 0V(as a replacement for LM324) so I downloaded the data sheet and SPICE model of TLC081 from TI.
It is stated in the data sheet that the common mode voltage of TLC08x includes 0V so I'm just checking how it performs via simulation in the configuration of a voltage follower with gain. The simulation result does not corresponds to what I am expecting.
It must be a bad Spice model from TI or compatibility of models in LTSpice then. The circuit and model is attached if you want to have a go.
So, have anyone ever used the TLC08x for sensing signal down to 0V?
