TL431 Shunt Regulator Resitor Values
Discussion in 'The Projects Forum' started by Baterka274, Jan 6, 2016.
  1. Baterka274
    Oct 2, 2015
    6
    I have got a circuit which works as high current shunt regulator and indicator of battery status (for stethoscope). Input voltage from battery is 9V and output voltage 5V. I have finished my indicator yet, but I am not sure about regulator and his values. Can you help me with values of resistors in this regulator (R16, R20, R22)? I use diode TL431 in this circuit.
    Thank you very much
    Tom
  2. GopherT
    Nov 23, 2012
    6,314
    4,033
    How about changing the title to something more descriptive. Like, "TL431 shunt regulator question"
  3. DickCappels
    Aug 21, 2008
    2,773
    669
    R16 and R22 need to be the same value for a 5 volt output. Each can be 10k ohms.
    As for R 20, how many milliamps is the load on your +5 volt output?
  4. ronv
    Nov 12, 2008
    3,401
    1,458
    You really don't need VR2 to regulate the voltage for the led.
    You can just set the LED current with a resistor.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    @ronv : He is using the left TL431 as a low voltage detector that lights on low battery voltage; not using it to regulate the current through the LED.
    @Baterka274 Dobry Den.
    Answer Dick's question about the load current...
