TL16C552A dual asynchronous communication element with FIFO
Discussion in 'Embedded Systems and Microcontrollers' started by Irmutis, Sep 30, 2009.
  1. Irmutis
    May 24, 2009
    17
    I have a problem, I need to understandt what does TL16C552A do? What is FIFO (I know that it is ''first in first out'') and why it is used in this element?
    I can't find easy understandable material in internet except Texas instruments datasheet. Could anybody help me and write me about it or write any good internet sites, links to pdf, books to download...
    This is datasheet
    http://focus.ti.com/docs/prod/folders/print/tl16c552a.html
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The FIFO is a buffer which holds onto received characters until the CPU can get around to reading them from the chip. This is especially important as the serial bus data rate is increased from say 9600 bits persecond upto 115,200 bits per second or higher.
    There may also be a FIFO on the trnasmitter, but this is generally less critical for the CPU.
    The chip also performs the functions of parallel to serial conversion and framing for the transmitter, and serial to parallel conversion and framing for the receiver.
  3. Irmutis
    May 24, 2009
    17
    Thank you :)
  4. Irmutis
    May 24, 2009
    17
    maybe anybody else knows something more?
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Does anyone still use that old UART? I take it this is a homework assignment.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Use the link to get the data sheet. It will explain in great detail just what the IC does and how it does it.
