TL071 vs LM386
Discussion in 'The Projects Forum' started by underground9, Dec 14, 2011.
  1. underground9
    Dec 13, 2011
    7
    I dont know much about amplifier ICs but what are the key differences between TL071 and LM386??
    Any links to read up and etc.. would be a great to :)
  2. underground9
    Dec 13, 2011
    7
    anywebsites where i can compare the two?
  3. MrChips
    Oct 2, 2009
    12,628
    3,452
    The TL071 is very different from LM386 and you would not interchange the two in any given application. The TL071 is a low noise amplifier intended to increase the voltage of a weak signal, for example, a microphone or guitar pickup.
    The LM386 is a low wattage power amplifier intended to drive a small loud speaker. This is used as the output stage of a low power audio amplifier, for example if you want to drive your PC speakers or the output of an MP3 player.
    underground9 likes this.
  4. nerdegutta
    Dec 15, 2009
    2,565
    806
  5. underground9
    Dec 13, 2011
    7
    I understood that they are completely different from each other. My question lies in so what are the key differences between the two
  6. MrChips
    Oct 2, 2009
    12,628
    3,452
    Well, didn't I already explain? Then I'm not communicating well at all. In that case the technical differences would be found by comparing the specifications sheets.
  7. underground9
    Dec 13, 2011
    7
    what about physical properties.. such as the input they can take.. what there made from..i understood what you explained above but im looking to go into more detail
  8. MrChips
    Oct 2, 2009
    12,628
    3,452
    The physical properties are the same. They are usually made from the same materials, silicon dioxide, boron, phosphorus, metal wires and bonded in plastic. The transistor processes may differ. One uses field effect transistors (FET) and the other uses bipolar junction transistors (BJT).
    The input parameters are different. One has very high input impedance.
    The output parameters are different. One has very low output impedance.
    The noise performance is also different.
    These are stated in their respective data (spec) sheets.
  9. underground9
    Dec 13, 2011
    7
    thanks but im finding it hard to read and understand them as its my first time reading them thats why im asking for help.
  10. MrChips
    Oct 2, 2009
    12,628
    3,452
    Learning to read data sheets is an important step in becoming a competent electronics designer. There are no shortcuts.
    I don't have the time now but I will return and give you some tips. For the time being, take a look at the spec sheet for TI LM386 (this is a pdf download):
    http://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=lm386&reg=en&fileType=pdf
    The parts you always read are
    • General Description
    • Features
    • Applications
    - all on the first page
    and the
    • Application Notes
    • Application Hints
    • Design Notes
    • Design Examples
    found later in the data sheets.
  11. crutschow
    Mar 14, 2008
    13,493
    3,372
    If you Google "reading datasheets" you will get many references explaining the subject.
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    The TL071 is an opamp with a voltage gain at DC and low frequencies of 200,000. It uses external negative feedback resistors to reduce its gain to a useable amount. Its minimum load is about 2000 ohms. It has very low distortion and low noise.
    The LM386 is a little power amplifier with a voltage gain of 20 because it has negative feedback resistors built-in. Its load is a speaker that is 4 ohms to 16 ohms and higher.
    Its distortion is fairly low and its noise is audible at low signal levels.
