TIP35C ???
Discussion in 'Analog & Mixed-Signal Design' started by R!f@@, Jul 5, 2016.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,792
    771
    I am confused....???:confused:
    Is TIP35C a darlington ?? The data I have says NO! :D
    This I wanna Buy. :rolleyes: I do not want darlingtons.
    But this says it a darlington.. o_O
    So what is it ???? :mad:
  2. OBW0549
    Mar 2, 2015
    1,395
    941
    Instead of taking the word of some doofus on Ebay, why don't you just Google "TIP35C" and look at the manufacturer's data sheet? It's not a darlington.
    MaxHeadRoom, R!f@@ and dl324 like this.
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    My datasheet says it is not a darlington.
    I was searching on Aliexpress and Ebay and both sites most seller is saying darlington. So I thought I ask around before buying.
    Thanks though.
  4. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Even if you don't buy from Digikey, their search when found also includes the PDF which avoids many of the surplus supply houses coming up when looking for a semi PDF.
    It shows the TIP35C as a complementary to TIP36C PNP.
    Max.
  5. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    Another chance to say "you can't believe everything you read on the internet".:rolleyes:
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The first site has a very wierd description for the TIP:
    • Model Number: TIP35C
    • Type: Voltage Regulator
    • Condition: New
    • Supply Voltage: International standard
    • Dissipation Power: International standard
    • Operating Temperature: International standard
    • Brand Name: new
    • is_customized: Yes
    • Application: pcb
    Asif the transistor is a voltage regulator.
    Also the line International Standard also tells you nothing about the part.
    The second site tells no specs at all.
    If you want the specs of a part, always try to locate a manufacturers datasheet.
    Bertus
  7. R!f@@
    Apr 2, 2009
    8,792
    771
    I have the Datasheet, from that I was searching for the part. But the more I looked the more confused I got.
    Any ways I already bought that part since it is not a darling....
  8. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
  9. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    It is a 100v NPN bipolar power transister, designed for general purpose power amplifier and switching applications.
  10. DickCappels
    Aug 21, 2008
    2,778
    674
    It is likely that many of the merchants selling electronic components and small assemblies on eBay and Amazon do not have any understanding of what they are selling. They appear to throw in many buzz words that might seem relevant, especially if that buzz word was used by a competitor. "If their transistor features Darlington then all of ours will too!"
  11. R!f@@
    Apr 2, 2009
    8,792
    771
    Well guess what ?
    I bought by looking at the picture from another seller cause it was a bit cheap.
    Just in case I msg him saying to send exactly as the picture. He replied now he have these and shows a picture of a fake type.
    Bummer..! I yelled at him and warned him to report to Ali express if he is showing misleading listings.
    I guess I will have to cancel and by from the original one I showed in post #1.
    But before buying I msg him to confirm his item is as shown in the picture
  12. R!f@@
    Apr 2, 2009
    8,792
    771
    Umm ! I am confused.
    How did this thread belong to Analog-and-mixed-signal-design-forum ?
    Isn't this just a general electronic related chatting ??
    Just thinking out loud why it was moved ?
