Hi all, Can anyone help me, i need to test a tip3055 in circuit of a power supply i dont know if it is working. I have an el cheapo vom. how do i go about this thanks for any help
Put some reasonable amount of load resistor on the power supply. 10% of its ability will work. Measure from ground or common to the collector to see if you have main voltage available. Next measure ground to base to see if a drive voltage is present. Finally measure ground to emitter to see if its voltage is about .5 to .7 volts less than the base voltage.
