TIP142 Stepper motor driver
Discussion in 'The Projects Forum' started by crazybuoy, Oct 3, 2010.
  1. crazybuoy
    Thread Starter Active Member
    Sep 19, 2010
    62
    Now, I have try this circuit with 24V DC, 1.7Amp power supply. But still the motor does take any step (forward or backward). I think the value of resister is very much big. What it should be?
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    I presume the -24 Volts in your schematic is a ground connection.
    Are you using Back-EMF diodes on the motor windings?
    If you are not using them the transistors may be dead by now.
    Bertus
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What are you using to drive the inputs to the bases?
    If a logic level (say, 0v=0ff, 5v=on), then you need to calculate the base resistors using that lower voltage.
    Rbase = (Vin - 1.4v) / 10mA (this is specifically for the TIP14x with up to 5A collector current)
    Rbase = (5-1.4) / 0.01
    Rbase = 3.6/.01 = 360 Ohms.
    If you are switching the inputs using 24v, then:
    Rbase = (24-1.4)/10mA = 22.6/0.01 = 22.6k Ohms. You could use 22k or 23k.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Bertus,
    The TIP14x series have body diodes which would take care of the reverse EMF.
    However, using external reverse EMF diodes is a good idea, as it reduces the power dissipation in the transistor body.
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    @ SgtWookie,
    I see it in de datasheet that there are diodes in the transistors.
    What I also see is that the different manufacturers have different resistors accross the two bese emittor connections.
    Fairchild shows 120 Oms for R2.
    ST shows 60 Ohms for R2 and
    ON shows 40 Ohms for R2.
    Is this off influence of the base current?
    Bertus
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Switching transistor aside, it would be interesting to know how and in what sequence the transistors get switched.
  7. crazybuoy
    Sep 19, 2010
    62
    Thanks, then are there some good articles. Please provide me some links. I know, that I can also search but can not think which is batter one.
  8. crazybuoy
    Sep 19, 2010
    62
    Now following stepper driver is successful to run the steps of motor. But there is a problem that the transistors turn hot very quickly. What is problem here. I think the resistor is small. Is it?
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Darlingtons get hot because they have a high Vce(sat); the output transistor never truly saturates like individual bjt's do (bjt=bipolar junction transistor).
    Replacing the Darlingtons with logic-level MOSFETs would help the situation enormously.
    IRLZ24, IRLZ34, IRLZ44 N-ch power MOSFETs are pretty common.
