TIP127 current calculation....
Discussion in 'General Electronics Chat' started by RRITESH KAKKAR, Dec 30, 2013.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I am using TIP 127 for controlling current of led as load, i have connected the emitter to +12V and collector to led series of 4 (2.2 x 4= 8.8V) using SMPS.
    The base is connected with pre set 10K resistance to GND of 12V.
    data sheet says 5A with 120mA...maximum..
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Hmm not sure what you are asking for here. Post your planned schematic please
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    sorry base was with GND only...
    but how to control current i think TIP is not suitable for controlling current in between 300mA to 1.5A
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You have nothing to measure / control the current.
    You could try the following circuit:
    Bertus
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Would it not be better to use PWM in this case. Then using the OPs method heat sink for the transistor will be required
  6. sheldons
    Oct 26, 2011
    616
    101
    have a look at this simple circuit.....
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Ritesh, what LED has a forward drop of only 2.2V with a forward current of 1.5? All of the high-current LEDs I have looked at have much higher forward drops...
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    there are series of 4 led red and many series are connected in parallel....
    i want to control current without using so many series resistance, as before bc337 was used which was working fine for low current ~250mA but now i want more brightness by controlling its current not using PWM because there will be many other led series for flashing on display .
    i am using smps of 12v 4A
