TIP 31 A equivalent
Discussion in 'The Projects Forum' started by The Engineer, Mar 24, 2015.
  1. The Engineer
    Sep 3, 2014
    35
    I'm am about to print out a PCB in order to build a metal detector , here is the design. http://www.geotech1.com/pages/metdet/projects/twinloop/twinloop.pdf
    I am missing a transistor, a TIP31A.
    Have looked in a alternative transistor catalogue and have found no results for this component, So I am wondering if anybody on the forum knows of any possible alternatives that will just about to the job ?
    Need to hand the detector in in two days so any advice will be very helpful !
    Thanks guys.
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    If you can't buy, what numbers do you have or get ?
  3. The Engineer
    Sep 3, 2014
    35
    I have 32C, 34, 41, 120, 121, 126, 127, 3055. And many other transistors available as i'm in college so name any you believe will work !
  4. Jim Brooks
    May 19, 2014
  5. The Engineer
    Sep 3, 2014
    35
    I do not have time to order unfortunately ! if you could name any you belive will work I will check if they are in the store room
  6. MCU88
    Member
    Mar 12, 2015
    360
    35
    Why don't you read the datasheets yourself and see if you have an equivalent. Things to consider with comparison would be:
    • NPN or PNP?
    • hFE / Beta
    • Darlington / super transistor?
    • Bandwidth (MHz)
    • Voltage & current ratings
  7. MrChips
    Oct 2, 2009
    12,656
    3,461
    TIP41
  8. Dodgydave
    Jun 22, 2012
    5,172
    778
    Tip41
  9. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,710
    1,302
    TIP41 - yes. 5A instead of 3A, simple substitution.
    TIP121 - no. This is a darlington transistor, and might not behave the same as the TIP31 because of the different effective base-emitter voltage.
    ak
    atferrari likes this.
  10. tonyStewart
    May 8, 2012
    22
