tiny wire connectors
Discussion in 'The Projects Forum' started by aac9876, Jan 3, 2010.
  1. aac9876
    Thread Starter Active Member
    Dec 9, 2006
    124
    by the time I get done soldering tiny components,pins to lead wires, the mess of wire, solder and tape is bigger than the component itself. What do you use for tiny wire /pin connectors
    that keep things neat and under control..??? links...
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Got some part numbers? Tiny is a relative term. Mini-DIN 8's can be a bear, but Jones plugs are easy with a Weller gun.
  3. aac9876
    Dec 9, 2006
    124
    i mean the closest thing to a crimp sleeve connector except the diameter of a sewing needle...
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    Sewing needles come in all sizes too. Can you provide a picture of the problem you are trying to solve? Maybe give the gauge of wirer sizes you want to join.
    John
