Tina-TI help
Discussion in 'General Electronics Chat' started by ManiN, Feb 3, 2010.
  1. ManiN
    Feb 3, 2010
    I'm new to this site and would like some help using Tina-TI for circuits exploration. I've been trying to put together some 555/556 timer circuits to experiment with them, and cannot get Tina to emulate the circuit. It seems speratic that I'll look and one of the LEDs will be lit. I'm just trying to make a flashing light circuit and see the LEDs flash.
    Any help is great.
      File size:
      17.7 KB
      63
  2. kdillinger
    Jul 26, 2009
    141
    Please post the .SCH file from TINA.
  3. ManiN
    Feb 3, 2010
    It's TINA-TI, so it's a .TSC file. It's not on the list of files to upload, so I zip'd it.
    • 555.zip
      File size:
      1.9 KB
      27
  4. kdillinger
    Jul 26, 2009
    141
    You need to eliminate the floating voltage circuit. Have you calculated the duty cycle of the 555? You many not see it flash because the frequency is much too high.
    I do not have TINA-TI so I do not believe you have the transient analysis option where it will take time steps to infinity. I have the full version of TINA and I get errors in your circuit.
    TINA is sometimes flaky so it is not as stable as other Spice sims, but it is easy to get up and running in TINA.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    The competition.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    MikeML,
    Not a fair comparison, as LTSpice's NE555 model is "idealized", and not a model of a real 555 timer.
    Tina-TI doesn't consider a 555 timer an IC. You will need to include at least 1 IC to get it to run.
    You will also need to select an output point. You will not see the LEDs flash in the simulation; only waveforms.
