TINA questions regarding formating
Discussion in 'General Electronics Chat' started by WBahn, Aug 9, 2013.
  1. WBahn
    Thread Starter Moderator
    Mar 31, 2012
    18,088
    4,917
    I have two questions regarding controlling the display of TINA schematics.
    1) Does anyone know of a way to draw wires at non-orthogonal directions, such as at a 45° angle? I'm guess that this isn't possible, which is a shame.
    2) Is there anyway to turn off the box that surrounds text strings that you add to the schematic? It seems like this should be possible.
    Thanks!
  2. JoeJester
    Apr 26, 2005
    3,402
    1,227
    WBahn,
    There is no way for non-orthogonal directions. There are components you can select in 45 degrees though.
    The box and background of the text is turned off by selecting the appropriate background and border
  3. WBahn
    Mar 31, 2012
    18,088
    4,917
    Thanks a lot!
    It sucks that you can't do non-orthogonal wires -- you can just make some schematics so much prettier if you can. Oh well.
    Thanks for pointing out how to access the properties. I had actually tried that, but went straight to the "Properties" at the very bottom of it. I blame it on my eyes -- it is getting so hard to read things anymore. Hopefully within the next month I will get the cataracts removed from both eye.
