I am trying to make an automatic feeder. I have a timer which is an off the shelf item that operates on 6vdc that's going to be tripping solenoids that will allow the feed to be distributed. the issue is the shortest period of time i can set the timer to come on is 1 sec which can be forever when it comes to electrical stuff. the timer only has 1 output so I have all the solenoids in series with a NO/NC switch between them. Checkout the attached image. I want to use a 555 timer circuit to allow the solenoids to get power for a fraction of a second but i cant figure out what type or the exact components. there's astable, bistable, monostable........ I wasn't planning on having constant power to the timer circuit I was hoping to have the first 3/4 of a second of power to charge the timer circuit then the last 1/4 of a second to be allowed to pass on to the solenoids. so I guess i need advice on the type of timer and with the layout & exact components.
