I have used an infrared led and I want to control a light with it using 555 timer, I want to turn off the light again after sending ir rays. Is is possible with 555 timer?
The 555 is an acceptable choice because it is better to transmit a train of pulses at a set frequency and receive at the other end with a filter that only accepts that frequency - but you will need an integrator circuit to turn the burst of pulses when you press the button into a single pulse for the switching function.I have used an infrared led and I want to control a light with it using 555 timer, I want to turn off the light again after sending ir rays. Is is possible with 555 timer?
Thread starter | Similar threads | Forum | Replies | Date |
E | How can I make an oscillator with 3 capacitors? | Analog & Mixed-Signal Design | 38 | |
M | 555 timer frequency | Digital Design | 34 | |
R | How to bypass the timing of 555 timer to drive output low when required? | Digital Design | 15 | |
M | Timing Problem with First 555 Timer in Double Astable Circuit | Digital Design | 7 | |
C | PIC16F877 Timer/Timing | Microcontrollers | 10 |
by Aaron Carman
by Duane Benson
by Duane Benson
by Duane Benson
