Timer2 of PIC16F877
Discussion in 'Embedded Systems and Microcontrollers' started by ecaits, Jun 12, 2014.
  1. ecaits
    Jan 6, 2014
    52
    Dear Friends,
    I am working on TImer 2 of PIC16F877.
    Code is given below.
    Code ( (Unknown Language)):
    1.
    2. void main()
    3. {
    4.     TRISB0 = 0;
    5.     RB0 = 0;
    6.     inittimer2();
    7.
    8.     while(1)
    9.     {
    10.     }
    11. }
    12.
    13. void inittimer2(void)
    14. {
    15.     TMR2 = 0x00;
    16.     T2CON = 0x75;  // Prescaler 4, Postscaler
    17.     TMR2IF = 0;
    18.     TMR2IE = 1;
    19.     PR2 = 0xFF;
    20.
    21. }
    22.
    23. void interrupt ISR(void)
    24. {
    25.     if(TMR2IF)
    26.     {
    27.         RB0=~RB0;
    28.         TMR2IF=0;
    29.     }
    30. }
    31.
    But this code is not working.
    Can anybody suggest what may be the problem???
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Can you suggest what "not working" means?
  3. tshuck
    Oct 18, 2012
    3,531
    675
    I don't see GIE nor PEIE (see INTCON register, page 24 of the datasheet) being set - these are required to use interrupts and use peripheral interrupts.
    Please put your code between some code tags ([ code]//code goes here[/code ] - without the spaces), as this allows the code to be formatted nicer by the forum software.
    ErnieM likes this.
