try a10nF cap and a 145K resistor for the 1mSec, then use a 1.5K resistor for the 10uSec, if you use the hysterical osc circuit configuration, that uses pin 3 as the capacitor supply, you will need to put in two diodes in series with your resistors, one in each direction.
