Timer
Discussion in 'The Projects Forum' started by TAGMan, Jan 4, 2012.
  1. TAGMan
    Apr 1, 2011
    Greetings and Happy New Year to all
    I am currently working on a timer project that is in the "concept only"stage. I need a clock; a time clock that will provide a unique digital output for every second of its timing function. I dont really need an output at the "seconds" level but the "minutes level is required. ie: a digital signature for every minute of the 24 hr cycle. Then I will decode the signature as needed to detect the time.
    Thanks,
  2. wayneh
    Sep 9, 2010
    12,388
    3,245
    You may want to explain why you can't use this solution, available everywhere for ~$8.
  3. tracecom
    Apr 16, 2010
    3,879
    1,396
    DS1307 real time clock ic: http://datasheets.maxim-ic.com/en/ds/DS1307.pdf
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Using a realtime clock, you could put the minutes through a hash function, so each of the 1,440 minutes would be an n-byte long string.
    Or you could simply number the minutes 0000-1439
  5. Bernard
    Aug 7, 2008
    4,240
    414
    Depending on required accuracy, med a 555 IC, long term- count down 60 Hz line frequency. Connect 4 decade counters in series, 4017's. With a 4-input NAND gate decode 1440 for a common counter reset. Bring all outputs, except 1000's,& then just the 1000, to 31 positions of a solderless bread board. Use the other 4 in NAND to program any desired minute with just 4 jumpers.
