hello guys, a would like to ask if a cmos type 555 of 7555 can handle a timing period of up to 2.5hours basing on the equation T=1.1(R)(C), i want to use it in timing irrigation periods, thanks a lot
Only by using a very large value of resistor and/or capacitor.
Trouble is, your large value capacitor will have to be an electrolytic type which are not very accurate value. Also these capacitors have high leakage current. As your resistor will also be a high value, leakage is a problem.
Better to use your 555 as an oscillator driving a logic counter chain. When the last stage of the counter goes to logic 1 your time is up.
See the HEF4060B CMOS 14-stage counter with oscillator built in. Or the HEF4521 21-stage counter (no oscillator).
