timer with snooze
Discussion in 'The Projects Forum' started by blackstallion, Jan 13, 2012.
  1. blackstallion
    Jan 13, 2012
    8
    Hi, this is my first time to join this forum....i have been looking for an electronic project topic for my studies...i have been thinking on how to make a timer that have a snooze( maximum snooze reset 3 times).....any idea on how to achieve that?
    thanks...
  2. spinnaker
    Oct 29, 2009
    5,069
    1,176
    It would be really easy to do with a MCU like one of the Microchip PICs.
    You could even have a display and a real clock as opposed to just a timer.
    You would be able to set your snooze time, max times you can press snooze, all kind of options.
  3. simo_x
    Member
    Dec 23, 2010
    200
    6
    I don't understand exactly what you whant to do..
    Are you planning to make an alarm clock?
    If so it is better You do it with a microcontroller.
  4. blackstallion
    Jan 13, 2012
    8
    ok ill check on the MCU things on how it works..
  5. blackstallion
    Jan 13, 2012
    8
    my idea is to connect the timer to a motor and the motor will operate on the time that has been set on the timer....the snooze will only works maximum 3 times after snooze button is pressed...thats what im planning to do...
  6. spinnaker
    Oct 29, 2009
    5,069
    1,176
    Definite MCU application. You will even be able to control the speed of the motor if you want.
