It's causing the supply to be intermittently shorted via the transistor and LEDs.I totally agree with you that resistors are necessary for an led because i myself have fried a couple of them but in this case the switching is supposed to protect the led from frying.
You're already causing the power supply to be folded back (crowbar-ed). Increasing the current draw will only make the problem worse.Will putting a bigger transistor help me to manage the high current change.
Apparently, they are not. If they were, your timer wouldn't be resetting, and you wouldn't be asking for help, and basically ignoring the helpful responses.I'll state the problem again.
The circuits are working perfectly.
You need to post the specifications of the IR LEDs that you are using (preferably, the datasheet) and a better schematic.PS. the circuits are working perfectly if the inputs are connected independently. (I've tested it well)
- I don't think i'll be able to add a resistor because the output is not enough. You need to replace the already-damaged LEDs and use correctly valued current limiting resistors.
- I'm using a remote for the led signal because the 555 astables i built were not able to give me enough power without frying the leds. Had you used the proper value of current limiting resistors for your LEDs, you would not have fried the LEDs.
- Using the remote has solved this problem but the current draw is too high.this is causing fluctations. Use current limiting resistors on your LEDs.
- Is it possible to get the same output after reducing the currrent. Not with damaged LEDs.
- If not, how can modify the circuit to manage the changing current. Use properly-valued current limiting resistors on each LED.
Please don't feel that i'm not heeding your advice. Please let me know if i can get the same output with lower current
What size resistor did you use? What formula did you use to calculate the resistor size?i have tried using a resistor but the loss is so high
Well, that should simplify your problem somewhat. Why don't you go back to that store, and ask the store manager for the specifications of the LEDs that you purchased?I tried using a 100Ω resistor in series with each of the leds,but as i have said earlier the result was disappointing.
I must confess that i did not try any other values
As for the led specifications, i have no idea because, i bought them from a local store.
I'm not sure where you're getting 4v from, as you're using a 7805 regulator - which should output 5v, if the input voltage is at least 7v under load.What would be the recommended lowest value such that i would get a really bright output while still protecting the led?
(The input is 4v)
That doesn't cross-reference to much of anything.The transistor i'm using is 188 (I don't know if it still exists because i found it in an old corner of my house)
