?????The battery current wont spoilt the circuit rite?
U mean Relay 1 and 2 works opposite(when relay 1 is energised,relay 2 deenergised)?I'll have to get back to you on an elaborate explanation of the circuit...my wife wants to go out for breakfast.
How this works?When the ignition switch is turned OFF it triggers the timer.
I guess I missed the part about the handbrake. Is there an existing switch associated with it. If so, how is it wired in the vehicle, and is it open or closed when the brake is set?
Can we use relay to avoid this?This supplies some power to the timer circuit through R1
Is it ok if i use NE555?If you can't get a CMOS 555 (best option) then go with the one you have.
I couldnt find the digital circuit in the net,thats why i turn to use 555 timer.I suppose you could, but at that point I would switch to a digital timer solution...like a presettable count-down timer.
I don't have an NE55 to try, but it should be OK.Is it ok if i use NE555?
http://home.cogeco.ca/~rpaisley4/LM555.html#2 Use 330 for C1 and put in various values for R1 to find the time.I want to use switchable fixed resistor for variable timing,how to calculate it?
Thread starter | Similar threads | Forum | Replies | Date |
Timer-relay setup for reversing DC motor polarity | General Electronics Chat | 4 | ||
R | Timer OFF Relay help! | General Electronics Chat | 41 | |
Led Timer Integration/120v AND Gate Circuit | Power Electronics | 7 | ||
T | Solid State relay and timer circuit | Digital Design | 35 | |
C | Two stage timer circuit for relay | Digital Design | 10 |
by Duane Benson
by Aaron Carman
by Duane Benson
