Timer relay circuit
Discussion in 'The Projects Forum' started by tony7h, Jun 19, 2007.
  1. tony7h
    Jun 19, 2007
    hi
    i have a little theoretical project where i have 2 relays (1x 1min relay, 1x 20min relay). 1 start button, 1 stop button and a fan. i need to press the start button and the fan runs for 1minute then off for 20minutes then starts again for 1minute and continues looping till the stop button is pressed. i would welcome any help with a hard wiring diagram.
    cheer
    Tony
  2. JoeJester
    Apr 26, 2005
    3,402
    1,221
  3. tony7h
    Jun 19, 2007
    nothing has been done to date on this project yet.
  4. mozikluv
    Jan 22, 2004
    1,437
    in short, you're asking for a schematic for an astable circuit that could operate as what you have describe. a 555 timer can do that for you which i believe is the simplest approach.
    i believe a circuit for that has already been posted here in the forum. pls do some research.
    moz
