timer on delay
Discussion in 'The Projects Forum' started by whsoj, May 28, 2013.
  1. whsoj
    May 28, 2013
    I am attempting to build push button control for an led system but I'm having trouble with building in a 3 sec timer on delay. Bottom line I have space issues and I need a package component. Can any of you guys/girls point me in that direction any kind of ic or relay with built in timer on delay 3 to 5 sec one more problem I'm limited to 3.6 VDC:confused:
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    You need to show your circuit schematic.
  3. LDC3
    Apr 27, 2013
    920
    160
    Yes, how about using an 74hc5555. With the correct RC network, you will get a delayed single pulse after a trigger.
  4. Dodgydave
    Jun 22, 2012
    5,134
    767
    Easy mate, use an ICM7555 timer chip, works down to 2Volts use figure 3 for the circuit.
    Or use this circuit,
  5. whsoj
    May 28, 2013
    Ok Awesome but will this send a trigger pulse, like one shot or will it send continuous voltage?
  6. t06afre
    May 11, 2009
    5,939
    1,222
    It can be used as both depending on how you configure it.
  7. whsoj
    May 28, 2013
    ok thanks! had to add at least 10 characters
  8. whsoj
    May 28, 2013
    schemeit-project.png this is what I got that more than likely wont work Mr Chips
  9. #12
    Nov 30, 2010
    16,657
    7,303
    Probably more like this:
