TIMER FOR PIC 16f877a using mikroC
Discussion in 'Embedded Systems and Microcontrollers' started by Danishmehmood, Aug 18, 2013.
  1. Danishmehmood
    Aug 18, 2013
    hi. I am a new user of PIC Micro-Controller.
    My questions are:
    Can we use timer of PIC for 5 Seconds?
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You can use it to increment a counter on rollover. Any duration you want.
  3. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Most PIC's have a T1OSC input where you can connect a common 32.768Khz clock crystal, and use T1 timer to roll over at exactly every 1 sec.
    Max.
  4. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Sure. No matter what kind of timer you actually pick, no matter what interval is it's max time you can always count timer intervals.
    Example: if yor max interval is .1 second, count 50 of them for 5 seconds.
    I've used a PIC to make a timer that can accurately (easily 2%) time 25 minutes; it could do more but that is all the customer required. That one uses a 1 mS timer as I recall.
