Trying to design an inexpensive way to have a music file play for 1 hour at 12 noon every day.
I'm thinking about using a timer circuit similar to one of these: LED String Timer.
Timers used for LED Xmas light strings go for 6 hours every 18 hours. To get the music file to play the timer circuit should close and hold a normally open switch contact for 1 hours duration every 23 hours. So obviously I need to replicate the circuit to adjust this timing.
Any idea what kind of timer circuit is being used?
How could you use that output voltage from the timer to close a switch contact? I'm thinking relay but that would use too much current.
Any help appreciated -
