Timer Design Help
Discussion in 'The Projects Forum' started by tigerapna, Jan 5, 2012.
  1. tigerapna
    Dec 14, 2011
    73
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The easiest way is to go with the flow, use the original schematic and add a 3 terminal voltage regulator.
  3. tigerapna
    Dec 14, 2011
    73
    What about controlling a 24V Relay?
    Can I use the same transistor/relay circuit but supply 24 Volts to the relay coil?
